Hello everyone,
When exporting to LumenRT from OpenRoads Designer (10.10.xx.xx), each time I get different results for custom line styles.
* For 2D line styles, either the dimensions are wrong either they are not exported (they show up correctly sometimes).
* For 3D line styles, they don't always get exported.
Do you have any idea why is this happening ? Is it something in the definition of these line styles ?
Best regards.
Would it be possible to share your files for review? If so you can use the following link:
https://bentley.sharefile.com/r-rd6e6984d2bfb45ff865e355f583d5a99
Please be sure to include the rsc files for the custom linestyles.
Update,
I tried using a new file, reprocessed the corridors and set the camera view before exporting (which is something I forget to the the previous times), and now all the elements are exported to LumenRT including 2D and 3D lines stules.
regards,
