I've been trying to utilize the Lookup table with item types. Right now I'm trying to have Item Type table use elements level as a lookup criteria.Basically using the following syntax.
But it returns N/A as if it can't find it. I'm using copy paste level names for my look up table so it shouldn't be a misstype. But it has difficulty drawing the information from the table to element properties.
In addition I've tried using Level ID as the searching criteria to no avail and Using Level while it's added in a different item type field to avoid having a full this.GetElement().Level as well failed.
