I am attempting to use the Vertical overlay tool and would like to know if I need my geometry in the corridor model to make this tool to work. At the moment I have the Corridor and Geometry in separate models.Cheers
Hi Andrew
For vertical overlay adjustment to work, geometry and corridor must be in the same DGN file. This command is not available when the geometry is in a reference file because the command creates a vertical alignment and the corridor must reprocess to determine criteria for the vertical alignment.
See more here:
docs.bentley.com/.../GUID-D66334FD-A802-49A1-B9EF-EEE816281FCF.html
Answer Verified By: Andrew Sluce
That's about what I expected. Thanks for your answer.
