DRAINAGE MODEL PERSITANT SNAPS
I noted the ability to removed persistent snaps in Geometry tools.
communities.bentley.com/.../persist-snaps-and-how-to-remove-snap-rule
Can these be removed for multiple items at once? I.e. A key in feature to remove persistent snaps everywhere.
For example, in my drainage model, I have persistent snaps remembering old Labels.
This trickles down and affects my FlexTable Output.
Would be helpful being able to remove the snaps all at once.
  • Not sure if this will be useful or not but there is a key-in "geometry snappersistence off" that may do what you want. We had an issue with Persistent Snaps enabling. I don't remember where I found this key-in but I added it to a macro that runs on startup and turns off the Persistent Snap. As far as I am aware it works across the board.
    Microstation CONNECT 10.17.00.209
    ORD CONNECT 2021 R1 10.10.1.3
    Microstation v8i SS 10 08.11.09.919
    Power InRoads v8i 08.11.09.615
    ProjectWise 10.0.3.453
    Answer Verified By: Tsholofelo Oageng
Reply
