I created a terrain from a corridor top mesh using the following ORD tool:
The mesh sits on top of the corridor precisely. However, the created terrain does not align with the mesh.
I.e there is a miss-match below where the created terrain does not align with the mesh
Another example is seen where the created terrain does not pick up the left edge of pavement
Is there a reason why this may be happening and a solution around it?
Terrains cannot include two points with different elevations at the same x,y coordinates so where there are vertical lines in the template the terrain will skip one of the points. The workaround is to put a slight slope/offset between the points so that the terrain can include both.
