Good morning,
What is the typical workflow for creating an existing DTM and a TIN from point cloud data?
I am using ORD connect and also have TopoDOT.
How should I go about doing this?
Thanks in advance
.LAZ but i know to convert them to .POD for ORD
actually .LAS not .LAZ
What format is your point cloud data? Are you starting with a .LAZ or another format?
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
I posted about some questions about this a while back: https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/205257/gpk-ss10-clipping-a-terrain-vertically
You can create a POD file and you can filter out extraneous elevations using tools discussed in the thread above. Create a terrain from that. Then I believe you can Export that terrain to a DTM
MaryB
