Hello everybody,any tips how to delete all annotation elements in one graphics group in OpenRoads? It seems graphics group is not working as well as I know it in MicroStation.We need to delete all annotation elements, which come from one Annotation Group, but it is not possible.Example: I annotate my centerline by Annotation group included in Feature Definition (for example stationing of horizontal controls points). Then I use Element Annotation command for annotation of stationing of regular points. Then I need to delete some of previous annotations, but all elements, not only one text element of them. How to do? Delete command doesn't work.I think the graphics group is answer (because all annotated elements are in one graphics group), but Delete command doesn't work for these annotation group elements.
Josef
OpenRoads 10.10
So, when you turn the Graphic Group lock ON, you can't delete the entire group?
MaryB
Microstation 08.11.09.919Power GeoPak 08.11.09.918Power InRoads 08.11.09.918
Yes, exactly. As I know it is behaviour from the first ORD version.
Hi Josef,
As far as I know, these are not Graphic Groups, but Named Groups that are hidden somehow. I have a VBA macro that I created that does exactly what you are trying to do - i will share tomorrow if you need some sample code.
I would suggest you put a ticket in to log this as an enhancement as it is definitely needed. At least having these Named Groups visible in the Named Group dialog would be very powerful and allow the users to not have to completely reannotate everything when one annotation group instance needs to be removed and reannotated.
Mark
OpenRoads Designer 2021 R2 (10.10) | Microstation CE Update 17 | ProjectWise CE 3.4
Hi Mark,
Thanks for quick answer and solution. I will create SR. The macro is not problem, good idea. I will try to do it, hope it will work. Named group you say, hmm.
You can rename the attached txt file to .bas and import into the mvba editor.
There are 3 subroutines, selectAnno, deleteAnno, deleteAnnoAll - the first will select all elements that match the currently selected elements Annotation Group instance, the second will do the same but delete all of them in the current model, and the third will cycle through all Drawing models in the current DGN and delete all elements created in the same Annotation Group instance.
Attribute VB_Name = "DeleteCivilAnno" ' VBA Macro to delete selected Annotation groups from Drawing Models - by M. Shamoun (18/07/21) Sub selectAnno() Dim oScanEnumerator As ElementEnumerator, oScanEnumerator0 As ElementEnumerator, ph As PropertyHandler Dim oGroupName As String, ph0 As PropertyHandler, oElement As Element, oSelected As Element, oModel As ModelReference If ActiveModelReference.Type = msdModelTypeDrawing Then If ActiveModelReference.AnyElementsSelected = False Then CadInputQueue.SendCommand "beep" ShowMessage "ERROR - No elements selected", , msdMessageCenterPriorityError, True GoTo finish Else Set oScanEnumerator0 = ActiveModelReference.GetSelectedElements oScanEnumerator0.MoveNext Set oSelected = oScanEnumerator0.Current If oSelected.ModelReference.IsAttachment = False And oSelected.ModelReference.Name = ActiveModelReference.Name Then Set ph0 = CreatePropertyHandler(oSelected) If ph0.SelectByAccessString("Groups[0].Description") = True Then oSearch = InStr(ph0.GetDisplayString, "\") oGroupName = Left(ph0.GetDisplayString, oSearch) If ph0.GetDisplayString = "" Then CadInputQueue.SendCommand "beep" ShowMessage "ERROR - Selected element is not Civil Annotation", , msdMessageCenterPriorityError, True GoTo finish End If Else CadInputQueue.SendCommand "beep" ShowMessage "ERROR - Selected element is not Civil Annotation", , msdMessageCenterPriorityError, True GoTo finish End If Else CadInputQueue.SendCommand "beep" ShowMessage "ERROR - Only elements in active model can be used for this tool", , msdMessageCenterPriorityError, True GoTo finish End If Set oScanEnumerator = ActiveModelReference.Scan Do While oScanEnumerator.MoveNext Set oElement = oScanEnumerator.Current countTot = countTot + 1 Set ph = CreatePropertyHandler(oElement) If oElement.IsGraphical = True And oElement.ModelReference.Name = ActiveModelReference.Name And oElement.ModelReference.IsAttachment = False Then If ph.SelectByAccessString("Groups[0].Description") = True Then oSearch = InStr(ph.GetDisplayString, "\") oNew = Left(ph.GetDisplayString, oSearch) If oNew = oGroupName Then ActiveModelReference.SelectElement oElement count = count + 1 End If End If End If Loop CadInputQueue.SendCommand "beep" If count > 0 Then ShowMessage CStr(count) + " element(s) selected in active model", , msdMessageCenterPriorityInfo Else ShowMessage "No associated Civil Annotation found in active model", , msdMessageCenterPriorityWarning, True End If End If Else CadInputQueue.SendCommand "beep" ShowMessage "ERROR - Tool can only be run in a Drawing model", , msdMessageCenterPriorityError, True End If GoTo finish skip: finish: CommandState.StartDefaultCommand Exit Sub End Sub Sub deleteAnno() Dim oScanEnumerator As ElementEnumerator, oScanEnumerator0 As ElementEnumerator, ph As PropertyHandler Dim oGroupName As String, ph0 As PropertyHandler, oElement As Element, oSelected As Element, oModel As ModelReference If ActiveModelReference.Type = msdModelTypeDrawing Then If ActiveModelReference.AnyElementsSelected = False Then CadInputQueue.SendCommand "beep" ShowMessage "ERROR - No elements selected", , msdMessageCenterPriorityError, True GoTo finish Else Set oScanEnumerator0 = ActiveModelReference.GetSelectedElements oScanEnumerator0.MoveNext Set oSelected = oScanEnumerator0.Current If oSelected.ModelReference.IsAttachment = False And oSelected.ModelReference.Name = ActiveModelReference.Name Then Set ph0 = CreatePropertyHandler(oSelected) If ph0.SelectByAccessString("Groups[0].Description") = True Then oSearch = InStr(ph0.GetDisplayString, "\") oGroupName = Left(ph0.GetDisplayString, oSearch) If ph0.GetDisplayString = "" Then CadInputQueue.SendCommand "beep" ShowMessage "ERROR - Selected element is not Civil Annotation", , msdMessageCenterPriorityError, True GoTo finish End If Else CadInputQueue.SendCommand "beep" ShowMessage "ERROR - Selected element is not Civil Annotation", , msdMessageCenterPriorityError, True GoTo finish End If Else CadInputQueue.SendCommand "beep" ShowMessage "ERROR - Only elements in active model can be used for this tool", , msdMessageCenterPriorityError, True GoTo finish End If Set oScanEnumerator = ActiveModelReference.Scan Do While oScanEnumerator.MoveNext Set oElement = oScanEnumerator.Current countTot = countTot + 1 Set ph = CreatePropertyHandler(oElement) If oElement.IsGraphical = True And oElement.ModelReference.Name = ActiveModelReference.Name And oElement.ModelReference.IsAttachment = False Then If ph.SelectByAccessString("Groups[0].Description") = True Then oSearch = InStr(ph.GetDisplayString, "\") oNew = Left(ph.GetDisplayString, oSearch) If oNew = oGroupName Then ActiveModelReference.RemoveElement oElement count = count + 1 End If End If End If Loop CadInputQueue.SendCommand "beep" If count > 0 Then ShowMessage CStr(count) + " annotation element(s) deleted from active Drawing model." & vbNewLine & vbNewLine + "Removed Annotation Group: " + vbNewLine + Left(ph0.GetDisplayString, oSearch - 1), , msdMessageCenterPriorityInfo, True Else ShowMessage "No associated Civil Annotation found in any Drawing models", , msdMessageCenterPriorityWarning, True End If End If Else CadInputQueue.SendCommand "beep" ShowMessage "ERROR - Tool can only be run in a Drawing model", , msdMessageCenterPriorityError, True End If GoTo finish skip: finish: CommandState.StartDefaultCommand Exit Sub End Sub Sub deleteAnnoAll() Dim oScanEnumerator As ElementEnumerator, oScanEnumerator0 As ElementEnumerator, ph As PropertyHandler Dim oGroupName As String, ph0 As PropertyHandler, oElement As Element, oSelected As Element, oModel As ModelReference If ActiveModelReference.Type = msdModelTypeDrawing Then For Each oModel In ActiveDesignFile.Models If oModel.Type = msdModelTypeDrawing Then countDrawings = countDrawings + 1 End If Next If ActiveModelReference.AnyElementsSelected = False Then CadInputQueue.SendCommand "beep" ShowMessage "ERROR - No elements selected", , msdMessageCenterPriorityError, True GoTo finish Else Set oScanEnumerator0 = ActiveModelReference.GetSelectedElements oScanEnumerator0.MoveNext Set oSelected = oScanEnumerator0.Current If oSelected.ModelReference.IsAttachment = False And oSelected.ModelReference.Name = ActiveModelReference.Name Then Set ph0 = CreatePropertyHandler(oSelected) If ph0.SelectByAccessString("Groups[0].Description") = True Then oSearch = InStr(ph0.GetDisplayString, "\") oGroupName = Left(ph0.GetDisplayString, oSearch) If ph0.GetDisplayString = "" Then CadInputQueue.SendCommand "beep" ShowMessage "ERROR - Selected element is not Civil Annotation", , msdMessageCenterPriorityError, True GoTo finish End If Else CadInputQueue.SendCommand "beep" ShowMessage "ERROR - Selected element is not Civil Annotation", , msdMessageCenterPriorityError, True GoTo finish End If Else CadInputQueue.SendCommand "beep" ShowMessage "ERROR - Only elements in active model can be used for this tool", , msdMessageCenterPriorityError, True GoTo finish End If ' Save current model name currMod = ActiveModelReference.Name ' Cycle through models and delete matching annotation group elements For Each oModel In ActiveDesignFile.Models If oModel.Type = msdModelTypeDrawing Then totmodels = totmodels + 1 count1 = 0 Set oScanEnumerator = oModel.Scan oRun = 1 oModel.Activate ShowTempMessage msdStatusBarAreaMiddle, "Processing Drawing model " + CStr(totmodels) + " of " + CStr(countDrawings) + "..." Do While oScanEnumerator.MoveNext Set oElement = oScanEnumerator.Current countTot = countTot + 1 If oElement.IsGraphical = True And oElement.ModelReference.Name = ActiveModelReference.Name And oElement.ModelReference.IsAttachment = False Then Set ph = CreatePropertyHandler(oElement) If ph.SelectByAccessString("Groups[0].Description") = True Then oSearch = "" oSearch = InStr(ph.GetDisplayString, "\") oNew = Left(ph.GetDisplayString, oSearch) If StrComp(oNew, oGroupName, vbBinaryCompare) = 0 Then oModel.RemoveElement oElement count = count + 1 count1 = count + 1 End If End If End If Loop If count1 > 0 Then countMod = countMod + 1 End If End If Set oElement = Nothing Set oModel = Nothing Set oScanEnumerator = Nothing Next ' Return to original model ActiveDesignFile.Models(currMod).Activate CadInputQueue.SendCommand "beep" If count > 0 Then ShowMessage CStr(count) + " total annotation element(s) deleted from " + CStr(countMod) + " Drawing models." & vbNewLine & vbNewLine + "Removed Annotation Group: " + vbNewLine + Left(ph0.GetDisplayString, oSearch - 1), , msdMessageCenterPriorityInfo, True Else ShowMessage "No associated Civil Annotation found in any Drawing models", , msdMessageCenterPriorityWarning, True End If End If Else CadInputQueue.SendCommand "beep" ShowMessage "ERROR - Tool can only be run in a Drawing model", , msdMessageCenterPriorityError, True End If GoTo finish skip: finish: CommandState.StartDefaultCommand Exit Sub End Sub
