<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Created region measurement</title><link>https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/220326/created-region-measurement</link><description>Hi.
 I&amp;#39;m using PowerCivil.
 Is it possible somehow to create a region inside any shape (let&amp;#39;s say - color green few square objects) so the green color&amp;#39;s level is, for example, &amp;quot;Green_area&amp;quot; and later I can giglight (choose) all the green squares by the</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: Created region measurement</title><link>https://communities.bentley.com/thread/675260?ContentTypeID=1</link><pubDate>Tue, 05 Oct 2021 13:51:13 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:f3676408-4f6c-4249-9425-016473008e4c</guid><dc:creator>MaryB</dc:creator><description>&lt;p&gt;Can you clarify for me?&lt;/p&gt;
&lt;p&gt;You want to create green shapes, select those green shapes and use the Measure Area tool to get the area of all of them at once?&lt;/p&gt;
&lt;p&gt;You should be able to do that, selecting them by either the Element Selection tool, or using the SelectBy tool. Measure Area definitely works with a selection - I do that all the time for quantities. But yes, the level has to be turned on. If the level is not turned on, you can&amp;#39;t select or measure the elements.&lt;/p&gt;
&lt;p&gt;Can you describe HOW this isn&amp;#39;t working?&lt;/p&gt;
&lt;p&gt;Can you not select the green shapes?&lt;br /&gt;Have you selected shapes, but cannot get an area for them?&lt;br /&gt;Is there another step you are doing that I have missed?&lt;/p&gt;
&lt;p&gt;It is possible to have something that looks like a closed shape, but is actually an open line string that just happens to have the same start &amp;amp; end points.&amp;nbsp;That&amp;#39;s entirely possible. If you select the element, you would see that it is either a Line String or Complex Chain - these are open elements, even if they &amp;quot;look&amp;quot; closed. To create an actual closed shape, you would need to use the &amp;quot;Create Complex Shape&amp;quot; tool on that open element to actually close it so that it will measure an area.&lt;/p&gt;
&lt;p&gt;Perhaps you could attach a screenshot of what you have drawn so that we can more easily see what you are working with. A small drawing, containing just one or two of the elements that are giving you trouble would also be very useful.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
