I am trying to find the best workflow for creating construction staging cross sections. The project was modeled using multiple corridors across mutliple design files.
As Paul said, you can use refence clipping which I have found to be much easier than corridor clipping for creating staged cross sections. You can simply create a new drawing, reference the 3d corridor model, and clip mask or clip boundary within the 3d model. This will be reflected in the cross sections created within this drawing.
Answer Verified By: Joe Davis
