I'm having issues with my text sizes in ORD. When I label anything, the linework (leaders, ticks, etc) display correctly but the text size is completely off. In this case it is too small. How do I fix this?
Ryan:
I will go back to a tried and true idea: make sure that all of your dgnlib's, seed files, sheet dgnlib's etc. have EXACTLY the same working units. I can almost guarantee that somewhere within your workspace/ settings there are accessed files which are in disagreement in that manner. As well, make sure that everything which you desire to be annotative is annotative, and everything which you desire not to be annotative is not.
Mark
So I finally had a chance to get back to this project and try to make it work. You are right, if I use a 10,000 UOR seed to create my drawings all of the text is sized correctly. If I use the client seed set at 100,000 UOR all of the text is now 10x too small.
I have recreated all of my DGNLIB files to be at 100,000 UOR, but the software is still loading things from Organization-Civil and C: drive defaults. Do you know what I would have to enter into my cfg files to tell ORD to only read from the WorkSpace dgnlibs, and ignore the Organization-Civil level and the C: drive defaults?
