OpenRoads - Named Boundaries not Updating with Cells tied to Crossing Features
I'm using Openroads Designer and am trying to update named boundaries for cross section views. I added a 3D feature line in a reference file that is set up to display a cell when shown in cross section view (more specifically, a right-of-way line). It shows up fine when I create a new named boundary, but not when updating older named boundaries.
A few notes:
-Visible edges are in "dynamic" mode with live nesting set to 99 and display overrides set to "never".
-The level of the cell is turned on in 3D and still shows up in my level manager as active in the named boundary model, even with nothing else on that level.
-I've used the key-in "reference visibleedges allmodels synchronizecache", and nothing changed.
-I have detached and reattached the file with the cell reference but nothing changes.
Is there a solution for this that doesn't require re-cutting all my named boundaries?
Thank you,
Trevor
Parents Reply Children
