OpenRoads Designer Cross Section Side Slope Labels
I am trying to get our cross section side slopes to annotate properly and I'm not having any luck at all.  Referring to the images below, the side slope label is labeling between the top of slope point and fill point and not to the intermediate hinge point (the top image).  The segment labels should be 3:1 and 2:1 respectively (the bottom image).
I was going to create two different annotation definitions; one for cross slopes between the CL, EP and ES and another one for the side slopes that included those segments.  BUT, in testing it appears that in defining that way, I can't get the anything to annotate, at least in the preview I can't.
In the image below, I am using a slope annotation definition on the left that is defined using all segments and on the right I used the "new" annotation definition using a list of segments.
I did find a similar thread;
Openroads designer cross section labeling - OpenRoads | OpenSite Forum - OpenRoads | OpenSite - Bentley Communities
Has anyone else experienced similar issues with annotating cross sections?
Thanks in advance.
Chuck M
ORD 2020 Release 3 Update 9
Parents Reply Children
