Hi.
I'm using PowerCivil.
Here is the issue. As in the sketch below - black and red are two superelevation cases - normal and elevated. When elevated (in red), I want section 2' to be the same slope as section "2" and stop at he ditche's outer slope. I surely know how to do this in case 1' follows section "1", but don't know how to do this for the elevation stage.
Woukd appreciate any suggestions. Thanks.
Guys, solved issue 3 minutes after posting this. Nevar mind.
What was your solution? Other people might have the same question, and it would be very helpful if you could share what you figured out.
MaryB
