I'm trying to wrap my head around how to make a certain alignment for a new project.
The geometry will look something like this sketch:
How would I construct such a geometry?
Any tips would be appreciated.
Kind regards
Lucas Olsson
Hi Lucas
Had a quick play in ORD and come up with this -
Attached
Spiral.dgn
I created a series of overlapping Arc From Elements all with the same radius, then drew by exit straight and Arc between elements to exit. Complexed it together and run a vertical alignment on it.
Chris
AECOM Roads UK&I Digital Engineering, Design & Solutions Lead | Sector Information Management Lead
Associate Director – Digital
OpenRoads Designer 10.12 | MicroStation 2023 | ProjectWise CE 10.3.4 | ContextCapture | ProjectWise PowerShell 2023 | ProjectWise WSG API | Generative Components | OpenBridge Designer 10.12
Civil 3D 2023 | Dynamo | Navisworks Manage
PowerShell | Visual Studio | Office 365 | Power Platform | Teams | SharePoint | Visio
Speckle | BIMVision | Revizto | Solibri
Answer Verified By: Lucas Olsson
Thank you! Great explanation, very helpful.
Try the geometry builder, you can connect curve after curve into a complexe element. I have done this for doing spiral ramp for parking.
