Hi
I know that topic has been discussed here for many times now. But I am still struggling with exportin XS to DWG.
Basically my references ind drawing models have Visible Edges set to Dynamic ( shall I have cached? if yes, how can I change it for multiple drawing models, any variable? also I need to be able to update XS when adding new references to the 3D model)
During the save to dwg /export I have toggled on Merge Visible Edges, all other References are set to Merge. Convert references is toggled on.
And what I get is the sheet model with annotations and nothing else (no components, not terrain, etc).
Could you please share our workflow?
My only requirements is to be able to update XS whenever new reference is added to the "Master Model".
Thanks in advance for your assistance
now I do it in two steps, saving to DGN with merging visible edges, and then again to dwg.
Best,
Adam
OpenRoads Designer 2023 | OpenRail Designer 2023
Hi Adam, are you filtering the models you export?
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Answer Verified By: Adam Wieczorek
I export drawing and sheet models. It sometimes works and the other time I have nothing but annotations in sheets.
hmm this works okay for us...let me get a copy of our DWG settings file.
