Parametric constraints / transition
I am working on a trench model where I need to have some extra widenings. For that I have been using parametric constraints and they work just fine except in one place where it seems like ORD just ignores them and does it's own thing. I am asking what might be the issues since I need to export coordinate point for the trench bottom and I need it to be accurate.
For a better explanation I attached a screenshot with my issue.
Thank you very much
  • Andrei,
    To me it appears that there is an additional modeling station occurring in between your 2 parametric controls. I'd look into the Corridor Objects tool to see if there is a conflict. Things like Feature Definition Constraints (in the template), Point Controls and Superelevation all supersede a Parametric Constraint in regards to their priority in modeling. In other words, those other items will control your point instead of the Parametric Constraint, causing the "kink" in the transition that you are seeing.
    Hope this helps but it's hard to know what items you have in your corridor that might be affecting that transition.
    -Joe
    -Joe Muni
    Owner/President JAM Consulting
    InRoads-OpenRoads Consultant/ Project Support/ Staff Augmentation
