Is there a way to copy a number of items of ruled geometry all at once? I know that the copy geometry tool works on individual elements, but I need to create a large number of these indicative access' to run swept path analysis on them. Each one will be slightly different so I want to be able to adjust offsets and angles all at once. Is there a way to do this?
Seems like this might be a good appliction for a Civil Cell. I've never tried to create one with out vertical geometry, but I would think you should be able to.
www.envisioncad.com
ORD - 10.12.02.04 / 10.10.21.04 / 10.10.01.03 / 10.08.01.33Power GEOPAK / Power InRoads - 08.11.09.918Civil 3D - 2021 / 2022
Answer Verified By: Joshua Close
That is actually a great shout Steven! I ended up doing it in separate files for now, but will bear this in mind for the future.
