Creating centerline\ROW in ORD from graphics created in InRoads Power Survey SS2
I'm going to use graphics created with InRoads Power Survey SS2 to import into a file created with ORD 2020 R3 U9. Then follow the steps used in the centerline creation and R/W creation from the LEARN ROW fundamentals videos. I assume this should work.
The other item I was asked to do was generate a report for the alignment as is usually done in INR_PS SS2 (by the other office; I haven't don't an alignment; this is my first). I don't see any example of this in ORD that I can see. Suggestions?
Thanks!
