I created a simple two node/one conduit network. So far so good.
I then created a Profile Run using the Hydraulic Run from Node tool, and then the Project Run tool. I expect the stations of the node centers to agree in plan and profile, but they do not. What is happening here? And how do I fix this? I'm guessing I'm not doing something right.
I created what's shown below with the delivered Imperial WorkSpace to confirm what I am seeing in my custom WorkSpace, and it behaves similarly in both.
Is anyone else seeing this issue, or am I the only one?
I discovered that nodes draw correctly in profile only if the pipe connection region (shape or cone) is not used and is left to be the default node center. However, this is not usually the way manholes and pipes are modeled. Pipes are usually shown/designed to be connected to the interior of the manhole wall.
How can I fix this? Support and I have been working back and forth on this with, but no solution has been found.
