I am creating a boat load of cross sections in multiple files. While the cross sections themselves are coming in fine, when they are laid out on the sheet, they are uncentered and its quite tedious to have to keep manually re-entering a 100+ sheets (especially when I have to add a refence file, which causes me to have to recut the cross sections because I don't think their is a way to get new references to display on the cross section once it has been cut.).
Any ideas how to fix this?
Thank you.
Melody:
The variables which handle this issue are usually found in the workset cfg file. The variables are as follows:
CIVIL_CROSSSECTION_RT_TO_LT_SPACING = 0.00083333333 CIVIL_CROSSSECTION_TOP_TO_BOT_SPACING = 0.12500000000CIVIL_CROSSSECTION_SIDE_MARGIN = 0.00694444444CIVIL_CROSSSECTION_TOP_MARGIN = 0.30000000000
These values are for my needs, of course :-)
Mark
