In ORD 2021 R1, when creating plan and profiles, I am using the Annotation Group, Plan Grid. The labels for the grid lines are coming in square to the view but not parallel to the grid lines. What am I missing so that the text is aligned with the grid lines as the alignments in sheet views are always skew to the drawing borders? If I rotate the view/reference, the text remains square to the screen but not parellel to the grid lines.. See image.
That sounds like View Independent text. I believe you can check that in the properties. I'm not sure how to fix it off the top of my head.
MaryB
As part of my due diligence, I checked the example in Training and Examples. The Plan Grid Annotation Group was not used, I tried it and the text is orientated parallel to the sheet and not to the grid lines. This a bug in the software as there is no option for orientating the text parallel to the grid lines.
Thank you Mary, your answer should work.
David
David E. Stewart
Calgary, Alberta
ORD 2022R1
SrvReqNo:[7001330063]} Plan Grid Text is perpendicular to view. I submitted the LondonRd data set as the grid annotation is a supplied Annotation Group in that data set. As far as I can figure out, there is no control for the grid text orientation, if I am mistaken, please show me where this control exists.
This is part of the message that I received from Bentley support. This issue has been logged as a defect and our development team is aware of it.
Hi @David E. Stewart was this issue resolved on the ORD 2021R2 ? I'm experiencing the same problem on ORD 2021R1.
Thorkozane:
I have been out of town since the update, so I cannot answer your question. Sorry
Thokozane:
This is still a problem and is not resolved in 2022R1.
