Good-Morning All,
Is there a hierarchy when using parametric constraints, point controls and superelevation controls when modeling? Does one supersede another if all three are being defined?
Thanks in advance
Chuck
Hierarchy between point controls and superelevation is set by priority through the point controls button inside Roadway Designer. I'm not sure on parametric constraints. From the help:
Priority:
determines the order of controls on a point. This value only applies when there are conflicting controls on a point. Where there is a conflict, the control with the lower priority is applied (that is, lower numbers are applied first).
Tim
