Side slope annotation
I have some difficulties getting the side slope annotation to behave as I want. I am not sure if I have set it up poorly or if I am using the tool it the wrong way. I am using OpenRoads Designer 2020 R3.
If I remove any intermediate points and have the target in the same component as the source I get the side slope annotation as I want but not when I have them in separate components with points in between. I have a hard time explaining this so I took a few screenshots that can be seen below of the different template drops and the different results.
The first example, with this template I get the side slopes as I want:
The second example, here I only get side slopes on the outer slopes in the cut section:
Is there some workaround or have I set up the side slope annotation incorrectly? I am happy to add any other screenshots or files needed to evaluate why it's not showing correctly.
John A.
Parents Reply Children
