I'm working some alignments for roadway ramps and one of my baselines tied into an offset from the mainline centerline. That centerline was since edited/deleted but since my alignment was off of an offset from that line, it retained all of its smart features (only the offset got dropped). I managed to draw a new offset and switch the rules so that the last curve ties into that. Now I'd like to delete old line.
My question is: Is there a way to see if any other lines depend on that one similar to the arrows in excel? I can see what a certain element depends on, but I'd like to see all the elements that depend on a certain element. Second question is would this hold up if the dependent element is in another file (eg simple curve between 1 element in the file and another thats in the reference)?
Thanks!
HI Waleed,
Have you check the "Properties" of the element. The "Properties" dialog box gives all details about dependent elements. Please let me know if this helps, and this is what was expected.
Amita Shinde
https://communities.bentley.com/products/road___site_design/w/https://communities.bentley.com/products/road___site_design/w/
