I am using Power Survey SS2 to create a main alignment with several other alignments touching the main alignment. In order to have the stationing correct on one secondary alignment (it travels south to north, all the others were north to south), I had to use transpose.
This is what I got:
The way the text appears is the way the software put it in. It looks "odd" and I'm guessing that I'll be asked to change how it looks. Probably moving the "109 PI{" to the other side of the line and rotating the text 180 degrees). In other words make in look like the other alignments that run vertically rather than the main which runs horizontally. I can do this, and it's only one line, but part of me thinks that if I have to update this for any reason, the software with put in all back like you see it.
Is there a setting I should be looking at when running transpose, or is it just run it and fix it manually?
Thanks!
You probably will need to use a different stationing preference. You can copy the original by using Save As in the preferences dialog box and then modify the new version to flip things for alignments running opposite from the "normal" direction.
