My organization is having trouble with "Print Styles". When our Print Style is applied through the Sheet Index and Print Organizer, it is automatically seeking out a Cell Shape and putting a Fence around it. We wish to print around the Sheet Model border.
Our current workaround workflow is to launch the Print Organizer through the Sheet Index. This prompts the User to select a Print Style. The Print Style is selected and applied to all Sheets in the Sheet Index. However, when printed, a Fence is used as the "Print Area" and grabs the completely wrong area. We then have to use the "Convert to fixed print definitions" command on all sheets and change the Print Area from Fence to Sheet. The Print Style has been created with Sheet as the Print Area setting, however, this seems to be ignored in practice.
Anyone else experience this issue? We are using OpenRoads Designer Connect 2021 R1 - which may have something to do with it.
Not sure if I have seen this exact thing before. But, I can say the PO seems to always pick fence as the option, even when I select to only consider sheet models. You would think there would be a way to choose all sheet models and choose to print the sheet size in each sheet model....but I have yet been able to figure out a way.
Marc
