Does anyone ever run into issues with 2D Nearmap raster not being geolocated after attached? Never had that problem before and curious if anyone else run into the same problem.
The data is downloaded from Nearmap with the correct coordinate system chosen, and the attached option in ORD is set to "use sister file". But no matter how many different locations from multiple states, the image ended up in the Atlantic ocean.
-Wayne
Under Settings > User > Preferences > Raster Manager > Georeference ensure that your default unit settings are correct.
Answer Verified By: Wayne_Guo
Thanks Matt!!
The units were set to what they should be, but i did see the use sister file check box was not check. The image came right in correctly after it is checked!
