Here is the picture. Every time I create a node from Extract from Graphic (Using filter manager) ,I am ending up with multiple nodes.
Is there anyway where I can do it instead of deleting the nodes. The manholes are defined as extended elements in 2D dwg.Your help would be greatly appreaciated .Thank you for your time and help.
What software are you using, and which version of that software? There have been probably a dozen releases of ORD, so the specific version number would be helpful.DWG? or DGN? You mention DWG in your post, but your image shows the manholes are in a referenced DGN file. I don't know if that makes a difference, but it might.
MaryB
Yes, It is a DGN file and currently using ORD CE 2021 Release 1 Update 10.
Now, I'm currenly making one node at a time but If this filter works, It would be much faster.
Thank you for your response.
