I am trying to make surface for a bioswale and a GSRD. I have made the template as given below for both of them, but when I am trying to make a corridor for it, it doesn't show up. I am not sure why the end conditions are failing. I need help with this. Thank you.
If those are end conditions where things need to end, they need to be able to reach a conclusion. If there is no logical conclusion to be located within the component as defined, it will fail.
Not everything in the drawing should be an end condition. Anything that is not variable (depending on the end) should be a regular component. From what you are showing us, I can't determine if that is true. While I do not know the design intent of point "1_L" I do not believe that should be an end condition because it doesn't appear to be seeking for or solving for anything. What is the target for "1_L", what logic is being applied for it to solve? If there's nothing (and it's actually just a static line of your design) then it should not be an end condition.
An end condition that is supposed to intersect existing ground most often is defined with the "End Condition is Infinite" checked on because the existing ground is rarely ever exactly where we think it is supposed to be. Without that switch, the end condition will try to solve by the logic defined, but if the ground isn't at that exact point, it will fail to solve.
It would probably be helpful to attach your ITL here so that people can take a look at it because it is not obvious how all of the components in your template are intended to work. I see that "3_R" fails to solve, but you do not include a screenshot for "3_R". Points "_L" & "_R" do not solve, but I'm not entirely sure where those are in your template. And if they are the points "in the middle" of your swale, then they probably should not be end conditions - instead they would be Constrained components targeting some sort of feature or alignment with a profile.
MaryB
