Station wise quantity report for surface template corridor models in Open roads designer
Can you send the work flow to extract station wise quantity report for surface template corridor models in Open roads designer ?
Currently open roads extract end area volumes for linear template corridors only. but if i need station wise end area volumes between any two terrain models its showing values of "0" at all stations after analyzing cut-fill quantities for those two terrain models.
