Hello,I'm looking for a quick tip on creating geometry arcs for point control between corridor elements. For example like in the picture between existing circle and road lane. Creating any type of arc using the elements descending from corridor creates a recursive solution. I was wondering if there's a way to use the corridor elements but avoid "dependency". I have ways but they seem more or less inaccurate and really inefficient when there's everything I need right in front of me.
Reinis,
As far as I know, there are only two options to achieve what you're looking for.
Personally I suggest using option 1, because that will keep the design dynamic, even when you have to manually change the base geometry to mimic the corridor.
If I understood correctly your solution the only problem is that usually when creating a point control it requests an element with a "name" i.e line that has defined feature definition. Which I only know can be applied to geometry tools and in this case all of the arcs that can be created by elements become dependent on corridor when it's lines are used.
