Does anyone know why my Right of Way labels aren't displaying when I cut cross sections to sheets but they show up in my dynamic cross section view?
Below are a couple of pictures as-is from Dynamic View vs Cross Section Sheets
You might have the construction level turned off in your file's attribute. Can you check to see if the ROW cells are on the construction level?
Construction attribute is ON as are ALL Levels.
Was this issue ever resolved? I am having a similar problem. I set active profiles for all of the R/W lines and added them as references to the corridor. They show up fine in my dynamic section views but when I go over to the cross section sheets they do not display.
