How do you import and export hydraulic prototypes under Drainage and Utilities from one hydraulic seed file (.dgnlib) to another? I was able to export the inlet catalogs, but not the prototypes. I am working in OpenRoads Designer CE - 2021 Release 1. I am exporting to same version software.
I'm afraid that we don't have a way to do this in OpenRoads at the moment James. There is an enhancement request for this functionality to be added.
Do you have an enhancement # for that functionality? I would like to be added to that for future updates
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
Yes - it's Enhancement 1081400.
Jonathan - Do you have any updates on this enhancement request? This is a big need for large projects with multiple DU teams and many DU files. We really need a tool or workflow to keep our DU prototypes synced with the SUDA seed file. Thanks
If all team members are using the same SUDA SEED FILE dgn library, and that dgn library contains your prototypes, wouldn't that keep everyone in sync? Your maintenance would involve updating the prototypes in the one dgn library and then making sure that all team members receive (or are otherwise using through PW) the updated dgn library.
Karl Dauber, PEAdvance ConsultingLaurens County, SCkarldauber@advconsult.netwww.advconsult.netwww.linkedin.com/in/karldauber
