Using ORD 2021 Release 1 and Autocad C3D 2022. Profile Geometry Annotation lose values in export, K-value and grade change to 0.0 and Lines are exported between Profile IPs on Layer 0. Please find the Images.
Lalit
Have you tried a Save As instead of Export? Or, when exporting, make sure you merge all reference files. This issue was supposed to be fixed in the version you referenced.
There are problems exporting to DWg in 2021 R1, I do not recommend this version if you have to export.
For the exportation, in the export dialog option, you can select the differents models you want to export, the trick is: DO NOT SELECT THE PROFILE DRAWING then it should be fine
Save As does not create profile model, It creates profile in layout and i need a profile model in DWG
i tried in 2020 version that is exporting appropriately, i think you are right .however i need a solution for my ORD 2021 R1 .
