I would like to know if AutoTurn (Transoft Solutions) and if Vehicle Tracking (Autodesk) are compatible with OpenRoads Designer or if they will be soon?
Hi Mark Shamoun, I'm trying to integrate AutoTURN 11 with ORD 2021 Release 2 but having issues with the ribbon not showing up. I've tried other steps that you have put down as answers on other threads (Launching Autoturn in Connect - MicroStation Forum - MicroStation - Bentley Communities) but still no luck. I see that you help others quite frequently, any help is greatly appreciated.
Hi Kurt,
You will only see it is the "Drawings" Ribbon Workflow by default in ORD. You can Customize your ribbon to get the Autoturn tab in the "OpenRoads Designer" Workflow if you need it to be conveniently located.
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
Hi Mark,
That makes sense, I appreciate you getting back to me so quickly.
Kurt
Hi Mark Shamoun,
Would you be able to point me in the direction of some instructions on how to customize the ribbon to get the AutoTURN tab to show up? I checked in each of the variable sections (MS_MDL, MS_CMDTABLE_LOAD, MS_GUIDGNLIBLIST) and I do see that AutoTURN shows up in each of those respectively however I cannot find it under any workflow. I did right-click and went to customize ribbon and see that there is an AutoTURN tab that is supposed to load but it's not. I also see several other AutoTURN and AutoTURN Pro tabs as well so I'm not sure if I'm selecting the correct one. I appreciate you taking the time to respond and any help is greatly appreciated.
Do a ribbon search for "Customize Ribbon" and it will bring up a dialog you can use to move things around and change the ribbon.
There is some good info here:
Customizing Ribbons and Tool Bars - MicroStation Wiki - MicroStation - Bentley Communities
