Hi.
When I add a civil element (Line---Line Between Points) for an Horizontal gemometry and I press Enter after typing a value then I lock that parameter. OK. But is there any way to unlock again that parameter by keyboard (or shortcut) without having to move the mouse on the checkbox of the Tool Settings window to uncheck it?
And in the case of Profile (using Civil AccuDraw) with Station and Elevation parameters, how can I unlock one of them if "Station" and "Elevation" don´t appear in the Tool Settings window?
Thanks.
Use the END key to unlock a field.
Answer Verified By: Joan Martínez Serra
Mark is absolutely correct. As much as Bentley has attempted to introduce standard keyboard functions to MS Connect products, we- as legacy Microstation users- are always looking for other manners in which to accomplish tasks. Brain muscle memory is often hard to change.
Mark
Yes, it works!
Thanks both.
Regards.
