Civil Labeler needs
all of which were in a formerly coherent and data normal system.
Civil Labeler is delivered with a Labeler*.dgnlib. Why, oh, why?
I see the advantage of a number of those all in one file, but
I feel only horror, confusion and maybe a hint of betrayal in that there seems to be a, perhaps not arbitrary and certainly not pernicious but, deliberate muddying of the clarity "separate files for separate data object types."
So, what's the difference between the Text Favorites in the formerly complete Text Favorites.dgnlib and the new Labeler*.dgniib?
Why?
Hi Mark,
I was able to get the plan and profile drawing models to annotate properly using the civil labeler but had to re-assign the text favorites to the new civil element properties field terminology. I have not been successful with the xs annotation in the xs drawing models. Have you found a solution yet? I agree completely that it is very frustrating that the civil labeler will not label using the exact same text favorite that works when using the place label command.
Sean:
No solution as of yet... I am using our FD annotation groups still for profile (they work just fine), and running the basic label function for cross sections. Annotations in ORD still leave much to be desired.
Best Regards,
Mark
Thanks Mark.
There are some rumors floating around that the annotation library has some broken pieces when it comes to cross sections, specifically when using the civil labeler. A suggestion was made to use item types to store the drainage info and then assign. For what I will be doing the old place label tool will work.
