[DisplaySet] in the title of the view doesn´t disappear..
ORD 2021 R1  10.16.00.80
[DisplaySet] text located in the tittle of the views don´t dissapear When I do "Clear Isolate" from the Explorer (right-click on an element and in the context menu--- "Clear Isolate"). I have done before "Isolate".
Also when you do "Isolate" the text "[DisplaySet] don´t appear until you do zoom IN/OUT in the view.
I have also tried with "DisplaySet Clear" , "DisplaySet Remove","Update View",.. unsuccesful.
Thanks in advance.
  • DisplaySet is actually a View Attribute, and you can turn it off in the View Atrributes dialog. It turns on automatically when you create a DisplaySet, but doesn't automatically turn off just because you clear that set. (you might want another, for all the software knows)
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
    Answer Verified By: Joan Martínez Serra
