InRoad XML report CrossSectionPoint element with an Attribute of "ExistingCenterline"?
Does anyone know what makes an Evaluation Report produce a RAW xml file have a node "CrossSectionPoint" with a "Type" attribute equal "ExistingCenterline"?  Obviously it is picking up the points that makeup the template at the template drops of the corridor.  But a majority of the time this attribute Type is equal to "CrossSectionPoint" not "ExistingCenterline".  Does anyone know what controls this, or causes this?
<?xml version="1.0" encoding="iso-8859-1"?>
<InRoads productName="Bentley InRoads Suite V8i (SELECTseries 2)" productVersion="08.11.07.630" outputGridScaleFactor="1.000000" inputGridScaleFactor="1.000000" linearUnits="Imperial" angularUnits="Degrees" commandName="Cross Section Report">
	<CrossSectionSet setID="3" setName="Ex-XSlope-Test" alignmentOID="{D97B6FD8-920B-40F1-8F03-6019AEFF8978}" alignmentName="Ex-XSlope-Test">
		<CrossSectionStations>
			<CrossSectionStation leftOffset="-15.000000" rightOffset="15.000000" tangentialDirection="0.848102" radialDirection="2.418899" northing="735891.301345" easting="1692710.841221" elevation="615.997065" longitudinalGrade="-0.003648">
				<Station internalStation="0.000050" externalStationName="" externalStation="0.000050"/>
				<CrossSectionSurfaces>
					<CrossSectionSurface name="LIDAR existing conditions x-sections only" type="0">
						<CrossSectionPoints>
							<CrossSectionPoint type="CrossSectionPoint" northing="735900.301651" easting="1692702.904343" offset="-11.999981" elevation="614.927381" flag="Begin"/>
							<CrossSectionPoint type="ExistingCenterline" northing="735891.301331" easting="1692710.841234" offset="0.000019" elevation="615.997065"/>
							<CrossSectionPoint type="CrossSectionPoint" northing="735882.301012" easting="1692718.778125" offset="12.000019" elevation="615.343766" flag="End"/>
						</CrossSectionPoints>
					</CrossSectionSurface>
				</CrossSectionSurfaces>
			</CrossSectionStation>
			<CrossSectionStation leftOffset="-15.000000" rightOffset="15.000000" tangentialDirection="0.848102" radialDirection="2.418899" northing="735897.915389" easting="1692718.341450" elevation="615.947748" longitudinalGrade="-0.006215">
				<Station internalStation="10.000000" externalStationName="" externalStation="10.000000"/>
							<CrossSectionPoint type="CrossSectionPoint" northing="735906.915708" easting="1692710.404559" offset="-12.000000" elevation="614.804465" flag="Begin"/>
							<CrossSectionPoint type="ExistingCenterline" northing="735897.915389" easting="1692718.341450" offset="-0.000000" elevation="615.947748"/>
							<CrossSectionPoint type="CrossSectionPoint" northing="735888.915069" easting="1692726.278342" offset="12.000000" elevation="615.303967" flag="End"/>
			<CrossSectionStation leftOffset="-15.000000" rightOffset="15.000000" tangentialDirection="0.848102" radialDirection="2.418899" northing="735904.529465" easting="1692725.841717" elevation="615.924367" longitudinalGrade="-0.003074">
				<Station internalStation="20.000000" externalStationName="" externalStation="20.000000"/>
							<CrossSectionPoint type="CrossSectionPoint" northing="735913.529784" easting="1692717.904825" offset="-12.000000" elevation="614.718334" flag="Begin"/>
							<CrossSectionPoint type="ExistingCenterline" northing="735904.529465" easting="1692725.841717" offset="-0.000000" elevation="615.924367"/>
							<CrossSectionPoint type="CrossSectionPoint" northing="735895.529145" easting="1692733.778608" offset="12.000000" elevation="615.238414" flag="End"/>
			<CrossSectionStation leftOffset="-15.000000" rightOffset="15.000000" tangentialDirection="0.848102" radialDirection="2.418899" northing="735911.143541" easting="1692733.341983" elevation="615.876978" longitudinalGrade="-0.004556">
				<Station internalStation="30.000000" externalStationName="" externalStation="30.000000"/>
							<CrossSectionPoint type="CrossSectionPoint" northing="735920.143861" easting="1692725.405092" offset="-12.000000" elevation="614.723170" flag="Begin"/>
							<CrossSectionPoint type="ExistingCenterline" northing="735911.143541" easting="1692733.341983" offset="-0.000000" elevation="615.876978"/>
							<CrossSectionPoint type="CrossSectionPoint" northing="735902.143221" easting="1692741.278875" offset="12.000000" elevation="615.211808" flag="End"/>
			<CrossSectionStation leftOffset="-15.000000" rightOffset="15.000000" tangentialDirection="0.848102" radialDirection="2.418899" northing="735917.757617" easting="1692740.842250" elevation="615.852620" longitudinalGrade="-0.002954">
				<Station internalStation="40.000000" externalStationName="" externalStation="40.000000"/>
							<CrossSectionPoint type="CrossSectionPoint" northing="735926.757937" easting="1692732.905358" offset="-12.000000" elevation="614.767253" flag="Begin"/>
							<CrossSectionPoint type="ExistingCenterline" northing="735917.757617" easting="1692740.842250" offset="0.000000" elevation="615.852620"/>
							<CrossSectionPoint type="CrossSectionPoint" northing="735908.757297" easting="1692748.779141" offset="12.000000" elevation="615.191458" flag="End"/>
			<CrossSectionStation leftOffset="-15.000000" rightOffset="15.000000" tangentialDirection="0.848102" radialDirection="2.418899" northing="735924.371693" easting="1692748.342516" elevation="615.782411" longitudinalGrade="-0.007228">
				<Station internalStation="50.000000" externalStationName="" externalStation="50.000000"/>
							<CrossSectionPoint type="CrossSectionPoint" northing="735933.372013" easting="1692740.405625" offset="-12.000000" elevation="614.832509" flag="Begin"/>
							<CrossSectionPoint type="ExistingCenterline" northing="735924.371693" easting="1692748.342516" offset="0.000000" elevation="615.782411"/>
							<CrossSectionPoint type="CrossSectionPoint" northing="735915.371373" easting="1692756.279408" offset="12.000000" elevation="615.134286" flag="End"/>
			<CrossSectionStation leftOffset="-15.000000" rightOffset="15.000000" tangentialDirection="0.848102" radialDirection="2.418899" northing="735930.985769" easting="1692755.842783" elevation="615.764136" longitudinalGrade="-0.002428">
				<Station internalStation="60.000000" externalStationName="" externalStation="60.000000"/>
							<CrossSectionPoint type="CrossSectionPoint" northing="735939.986089" easting="1692747.905891" offset="-12.000000" elevation="614.887480" flag="Begin"/>
							<CrossSectionPoint type="ExistingCenterline" northing="735930.985769" easting="1692755.842783" offset="0.000000" elevation="615.764136"/>
							<CrossSectionPoint type="CrossSectionPoint" northing="735921.985449" easting="1692763.779674" offset="12.000000" elevation="615.090532" flag="End"/>
			<CrossSectionStation leftOffset="-15.000000" rightOffset="15.000000" tangentialDirection="0.848102" radialDirection="2.418899" northing="735937.599845" easting="1692763.343049" elevation="615.721052" longitudinalGrade="-0.005054">
				<Station internalStation="70.000000" externalStationName="" externalStation="70.000000"/>
							<CrossSectionPoint type="CrossSectionPoint" northing="735946.600165" easting="1692755.406158" offset="-12.000000" elevation="614.867040" flag="Begin"/>
							<CrossSectionPoint type="ExistingCenterline" northing="735937.599845" easting="1692763.343049" offset="0.000000" elevation="615.721052"/>
							<CrossSectionPoint type="CrossSectionPoint" northing="735928.599525" easting="1692771.279941" offset="12.000000" elevation="615.035679" flag="End"/>
			<CrossSectionStation leftOffset="-15.000000" rightOffset="15.000000" tangentialDirection="0.848102" radialDirection="2.418899" northing="735944.213921" easting="1692770.843316" elevation="615.711238" longitudinalGrade="0.000373">
				<Station internalStation="80.000000" externalStationName="" externalStation="80.000000"/>
							<CrossSectionPoint type="CrossSectionPoint" northing="735953.214241" easting="1692762.906424" offset="-12.000000" elevation="614.853820" flag="Begin"/>
							<CrossSectionPoint type="ExistingCenterline" northing="735944.213921" easting="1692770.843316" offset="0.000000" elevation="615.711238"/>
							<CrossSectionPoint type="CrossSectionPoint" northing="735935.213602" easting="1692778.780207" offset="12.000000" elevation="615.116099" flag="End"/>
			<CrossSectionStation leftOffset="-15.000000" rightOffset="15.000000" tangentialDirection="0.848102" radialDirection="2.418899" northing="735950.827997" easting="1692778.343582" elevation="615.684421" longitudinalGrade="-0.002888">
				<Station internalStation="90.000000" externalStationName="" externalStation="90.000000"/>
							<CrossSectionPoint type="CrossSectionPoint" northing="735959.828317" easting="1692770.406691" offset="-12.000000" elevation="614.915867" flag="Begin"/>
							<CrossSectionPoint type="ExistingCenterline" northing="735950.827997" easting="1692778.343582" offset="0.000000" elevation="615.684421"/>
							<CrossSectionPoint type="CrossSectionPoint" northing="735941.827678" easting="1692786.280473" offset="12.000000" elevation="615.071944" flag="End"/>
			<CrossSectionStation leftOffset="-15.000000" rightOffset="15.000000" tangentialDirection="0.848102" radialDirection="2.418899" northing="735957.442041" easting="1692785.843811" elevation="615.632357" longitudinalGrade="-0.006180">
				<Station internalStation="99.999950" externalStationName="" externalStation="99.999950"/>
							<CrossSectionPoint type="CrossSectionPoint" northing="735966.442343" easting="1692777.906935" offset="-11.999977" elevation="614.938506" flag="Begin"/>
							<CrossSectionPoint type="ExistingCenterline" northing="735957.442024" easting="1692785.843826" offset="0.000023" elevation="615.632356"/>
							<CrossSectionPoint type="CrossSectionPoint" northing="735948.441704" easting="1692793.780717" offset="12.000023" elevation="614.966179" flag="End"/>
		</CrossSectionStations>
	</CrossSectionSet>
</InRoads>
90% of the time I see "CrossSectionPoint" have the "type" attribute be equal to "CrossSectionPoint".
Thanks Again Folks,
