Thought this issue was a version issue (tried a various builds of SS2 and also with MS SS10, SS4, SS3). Also tried different seed files.
It was working previously but now no such luck:
Basically I have a user where the retaining wall Cross Section components are slightly shifted both H & V, and it's not consistent. The wall steps are correctly shown in Roadway Design, but not in Xsecs. We tried a different computer and got the correct results but I'm not sure if it's the users machine or a version issue. I matched the IR and MS version on machine that works, but still doesn't work on the user's machine. I could use a little enlightenment is someone has seen this before and knows the root cause and how to fix it.
Pics here, files attached..
0715000274_RW115_211104.dgn
0715000274_RW115_Test.dgn
Thanks in advance for any help!
Hi eMaarc,
Is the file opened with same workspace & workset settings? Any changes to the units, or the seed file?
Amita Shinde
Yep. I may be reaching, but I’m thinking this has something to do with Windows 10 interaction with the resolution of MS and/or IR.
Do you have template drops at the stations where the cross sections are shifted?
Best,
PE
