How can I edit a Driveway Pavement Width Default on Library ?
Hi Ademir,
Can you please elaborate the issue. If I have correctly understood your issue, you need to change the carriageway width, which you can achieve using the "Create Template" tool.
Amita Shinde
Hi Amita, thanks for reply.
I atached here a print.
I need chage the default value for Driveway Pavement Width to 3.00m. And I would like change another default parameteres, as sideways, medians, etc.
Regards.
