Proposed profile and alternative best practice
I have a proposed profile to create then an alternative.  Is the best practice to create these in 2 different alignment/profile files with the same alignment saved in each, then create the separate plan and profile files.  Or can they both be in the same file but each plan & profile sheets chooses which proposed they use.  The would both have the same feature symbology so I'm assuming that would create problems.
