Hi.
If I open the "Edit Template Drop" window and I edit the current template i.e; I remove the central component to have a "V" median can i save that current template to a itl file? Is there any way to change the name of that current template before saving it?
In the "Edit Template Drop" the menu bar File-Save, it saves the current itl file but I don´t understand what it does.
Thanks in advance.
From within the usual template library dialog. Ie access it via this button -> .
Select Tools->Template Library Organizer.
When it first opens up, you will have a folder on the right called Active Design File Corridors. If you expand this folder, it contains a list of all the corridors in the active file as well as the templates contained within them.
Simply drag across the templates from right to left, then rename to suit and save your template library.
Answer Verified By: Joan Martínez Serra
Thanks Liam from Barcelona.
Very useful.
I am trying the same thing but the corridor that has the template is not showing up in the Active Design File list.
Is there something I can try to get the corridor to show up?
This could be version specific. It was added sometime after the earlier releases, as I recall.
OK thanks
