If I open the "Corridor objects" window then in the category "Template Drop" I can see that the template was edited locally (because it´s name is in red) as you can see in the previous image.
However, if i press the button [...] to select the same name template from the active Template Library, it seems that it recognize it but the Corridor is not rebuilt automatically.
I have to select another template from the dialog window, it process the corridor automatically and then I have to press [....] to select the template I wanted the first time.
I don´t know if there is any way faster to do a "Update from Library" for Templates as we can do for styles in MicroStation with "Update From Library"...
Thanks in advance.
Use Synchronize Templates. Used against a corridor it will synchronize all templates within that corridor. Used against a template drop it will just synchronize that template drop.
Answer Verified By: Joan Martínez Serra
