I have annotations on a horizontal alignment that need to be 10 times smaller. What's the fast way to go about this? Without scaling. I can do them individually through each individual text node but that would take too long given the amount of annotations. I'm using ORD connect edition. Thanks!
Why not scaling? That would be your fastest option. You can scale "about element center" which for a text node is actually around the origin point.
The next best would be selecting them all and changing the text to the proper text style so that the scale is appropriate.
Either way you may still need to "touch" each one because resizing may require adjustment to the location.
Or you can look at how your annotation is set up to find why it is coming in so big, fix that, and redisplay.
MaryB
Thanks for your response, Mary. I was trying to avoid scaling because previous designers didn't. But that is what I ended up doing!
thanks again
Eric
Sometimes the job just has to get out the door...
