Regarding: Bentley OpenRoads, version: Bentley OpenRoads Designer CE 10.08.00.88
Error Message: Bentley OpenRoadsDesigner has stopped working.
Troubleshooting: Getting the error message immediately after opening the application. (Screenshot attached)Application newly installed and never worked fine.Showing license status of Bentley OpenRoads Designer as commercial in Bentley Licensing Tool.Refreshed policy and Sign out - Sign in to CC and again refreshed policy from Bentley Licensing Tool.Performed re-installation but still getting the same issue.
Hi Anuja,
Can you please make sure you have full control (read and write access) to the C:/Drive. Also, is this happening on your system only? If you have any other system where ORD is running fine, you may consider creating a deployment image and then install OpenRoads Designer on your system. Below link will help you create a deployment image. If still the issue persist, please send across the log files to check here.
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/33575/silent-install-deployment-image-for-openroads-designer-connect-edition
Amita Shinde
Hi Anuja
Is it a fresh install or was it working before and stopped recently? If existing likely to be an issue with pref and temp folders.
There could be also issues with ProjectWise (unsupported version) or your antivirus.
You might want to check your Windows updates or try a .NET repair: https://www.microsoft.com/en-us/download/details.aspx?id=30135
Yes, it is fresh install. I have access to temp folder in C drive.
.NET repaired issue still persist.
Could you please let me know the supported version of Project wise for Bentley OpenRoads Designer CE 10.08.00.88?
Yes I have full control (read and write access) to the C:/Drive.
Yes, this is happening on my system only for my colleague it is working fine. I don't have other system where ORD is running fine.
Created a deployment image and then installed OpenRoads Designer on my system as suggested in the link.
Still the issue persist.
Please let me know from where I can get the log files.
