I am trying to use the Model Annotation command to Annotate cross sections with cross slopes, offsets, and elevations of the pavement all at once. An Annotation Group was set up by somebody else and it is supposed to automatically apply these items after running the Model Annotation command. However, my cross sections are only showing elevations at the inside corners of shoulder pavement widening (as shown in the image below) and none of the other items generate. I'm not sure if it's an issue with the template or the Annotation Group. Does anybody know what would cause this and how to fix it?
Hi White,
Can you please make sure you are using the right workspace and workset settings that contain this annotation group? Also, is it happening on all the projects or this project in particular? Can you open the "Manage Annotation" for this annotation group to check if the annotation does have all the properties.
Yes, I am using the correct workspace and workset settings that were set up by our organization. This is the first project I've ever done in ORD that involves cross sections, so I have no other projects to compare to. Although I can get to the "Manage Annotation" screen, I'm not familiar with its functionality and how to manipulate the settings to get everything to appear as it should on the cross sections. Does Bentley have a training manual or video that goes over this topic?
