I have a Template only with Null Points (there is no Template Components).
In this case, I cannot see the Template Drop (magenta dashed line) in the Corridor in plan view. The feature Definition of the Corridor has "Include Null Point Linear Features Display" but I just see them in a 3D view.
Is there a way to show the manipulators of the Template Drop in a plan view when Template is based only with Null Points?
Thanks in advance.
I'm not aware of a way to accomplish what you're asking, but what's the harm in adding a dummy component to your template? Give it a nice, wide width. Have it follow your origin point with horizontal & vertical constants. Use a feature definition that you can easily turn off. Name it "IGNORE ME" or similar. I've done this many times and never had any issues.
