Hi.
I'm using PowerCivil.
Whenever I try to open Cross Section view to see pavements location at different stations, the chosen window is empty. And it doesn't matter whether I choose Corridors or Alignment to create cross sections.
Is there anything I'm missing in preferences or somewhere else?
Thank You.
What version are you using?
Is your corridor complete, and do you have a surface set to active?
MaryB
I'm using Power Civil for Middle East V8.1
Can You be more specific with "Is Your corridor complete..."? I mean I do have all the components for the corridor - horizontal alignment, vertical alignment as well as corridor itself.
Do you have a surface set to active?
V8.1 sounds like a very old version. I don't remember all the quirks of that one. Hopefully someone here with a better memory can see this and have better ideas.
