Is there any way to extract the Proposed Road Level at particular chainages from Mx Road Model. (ex. Chainage at Ch. 72+520.253)
Try below steps from the attached video
Best Regards,
Kugan (Account Manager & Technical Adviser on MX and ORD)
Sir I got it from your video, to view at one or Two chainages I can follow your steps. I have bulk chainages by this process it will be time consuming. Is there any way using Input file we can generate the report of FRL at required chainages.
EDIT,DESIGN017,CURV026,3=MC10,5=711.283999
EDIT,DESIGN <your design model>017,CURV026,3=MC10 <Master string>,5=711.283 <chainage>999
Sir when the Point is created on Master String then how to generate the report ?
REPORT,DESIGN 992,MC10,2=FULL999output,all ch.txt999
